May 5, 201510 yr Hey doing my 2nd trans swap. Dont kmow original trans code. However, the bad trans is TZ1A2ZJEAA-WY. I THINK IT CAME OUT OF A 98 GT. NEW ONE ALSO A GT I THINK. TZ102Z2DCA-KE. Its a outback body. Thanks
May 5, 201510 yr The trans code you posted is the same as what I took out of my 99 legacy GT, you cannot use any transmission older than the 99 model year. They are electronically incompatible. I'm not the best at deciphering the auto transmission codes, but I believe the one you have as a replacement is the wrong gear ratio, and also a phase 1 trans which won't work for you.
May 5, 201510 yr yeah, you'll be wasting your time trying to put that 98 trans in. You're looking for 1999-04 Outback, Forester or Impreza RS automatics most likely as they will be same phase and likely same final drive ratio. You can use Legacy and Impreza phase IIs so long as you also get the rear differential to match and swap that in. Get the final drive for your trans (probably 4.44) and make sure whatever trans you get to replace it is a match by checking its code before you purchase. There are more of these generations showing up in pick n pulls lately. Use row52.com to find a good donor in the self service network.
May 5, 201510 yr 04 will require additional work, subaru inverted the polarity and function of the duty c solenoid. If you use an 04 you'll have to swap out the solenoid and a couple other parts to make it work with your tcu.
May 6, 201510 yr Author Thanks for the fast replies. I'm thinking that my 1999 is more like a 1998 outback. phase 1. Im just learning about phase1 and phase 2. I understand that external trans filter is phase 2. I pulled moter and trans out of a donor. Should have keep my original trans. however, the TZ102Z2DCA (97-98 Legacy GT) electronics fit perfect. I know that 99 was a change over year. I think im living in the past. I found lots of trans code info on the TZ102Z2DCA (97-98 Legacy GT). and not so much on the TZ1A2ZJEAA They look very similar. As for the final gear. 4.44 was used on most outbacks? and GT's? In the past i have jacked up the back end of a 4 runner and counted wheel rotations to get rear diff gearing. Does anyone know if that trick works on subaru?
May 6, 201510 yr All 99s had phase 2 transmissions, 99 Legacy Outback and GT still had phase 1 engine electronics though so you may be getting confused there. Been dealing with subarus for 18 years and I've never seen an exception to that. The wiring may plug up but it will not function correctly. The easiest way to tell what phase the transmission is would be to count the motor to transmission bolt holes, 8 is phase 2 and 4 is phase 1. There are also several cases of a phase 2 transmission not having the spin on filter, some markets go slight variations. Edited May 6, 201510 yr by 86BRATMAN
May 6, 201510 yr +1 to 99 being all Phase II trans. don't Phase II's have more speed sensors - is that immediately notable visually?
May 6, 201510 yr There are 3 speed sensors on phase 2 transmissions, all on the left side of it and they are integrated into the transmission harness. Whereas there is one on phase 1, on the right side by the differential, and it plugs into the body harness.
May 6, 201510 yr I paid $900 for a used unit from F and S in Waterbury and around $500 for installation by J and J in New Milford. It has been running fine since, some slippage buy Lucas helped a lot.
May 6, 201510 yr Author Yep I stand corrected. sorry to question. I guess it was hopefull thinking. Looking closer last night proved that it aint gonna work. The replacement trans TZ102Z2DCA (97-98 Legacy GT) has only one speed sensor. My current bad trans has the three sensors and more wires coming out of it. Plug looks simmilar but not so easy to see. So i guess that trans will go back on craigslist. Thanks for saving me a ton of head scratching and flustration. really really big thanks
May 6, 201510 yr What exactly is your issue with the current transmission? Delayed engagement into drive and reverse is very common in the 99/00 automatic transmissions, and it can be fixed by a mechanically competent person with a few seals from the dealership for not a lot of money.
May 6, 201510 yr Author it started out on a wet 3 hour drive. I went through a clover leaf freeway entrance, about a n hour into drive. in the turn motor rpms went high and car slowed. as i intered freeway things returned to normal. driving at freeway speeds couldnt tell there was a problem. exit of freeway into city and car was really slow to move. rpms seemed normal. slowly parked it as it was barely moving and it smelled hot. not an engine oil smell but i figured trans oil. later drove it 20 min. home and it was impossible to park it. the trans oil looks clean and not burnt on inspection. I'm guessing it the gear box but assume it easier to replace whole thing. thanks again
