May 14, 201510 yr i had an earlier post on swapping a ej22 out of a 96 legacy into my 99 sus, we went back and forth getting the timing right, i finally got the timing right and i got the car running, it ran but it had a code for the crank shaft not being in sync with the cam, we replaced the crank sensor and the car ran beautifully for 15-20 minutes, then all of the sudden the car ran like crap, my mechanic buddy hooked it to his scanner and came back that there is no pulse to the #1 cylinder injector, so as you can imagine the car runs on 3 cylinders, he was lead to believe that the ecu has gone bad, will a ej22 ecu work in a 99 outback sedan running a 96 legacy ej22? assuming that both cars are automatics? are the pinouts the same?
May 14, 201510 yr A little research and reading goes a long way. This is an endwrench article that is available from links in the endwrench sticky thread. "Legacy And Impreza Engines With No Injection Pulse #1 CylinderBuilt into the fuel injection controlunit is logic that will shut off the #1injector if the computer believes that itcan no longer control the Idle Air ControlValve. Remember this design characteristicif you are trying to diagnose a “hard”code for the Idle Air Control Valve or adead miss in the number one cylinderdue to no injection at idle. A problem inthe Idle Air Control Valve circuit may beresponsible. (Component testing showsthat it most likely is not the valve itself.)Also, if the computer is deprived of its“back up power supply,” some computerswill generate a false code for the IdleAir Control Valve and kill the injectorEnd Wrench14End Wrench Thefor cylinder #1. The pin location of thispower supply can be found in the ControlUnit Module I/0 Signal pages of theappropriate Service Manual." http://www.northursalia.com/techdocs/pdf/engine/emissions.pdf
May 14, 201510 yr what check engine light codes are you getting? yes - a 1996-1998 EJ22 ECU will work, but not a 1999 EJ22. interesting read up there about cylinder 1 signal and IACV, crazy
May 14, 201510 yr I had a 99 sus and did same swap. 96 2.2 and all. I thought a 99 legacy sus or outback had a one year only ecu because of the phase 2 trans and phase 1 engine electronics
May 14, 201510 yr Author A little research and reading goes a long way. This is an endwrench article that is available from links in the endwrench sticky thread. "Legacy And Impreza Engines With No Injection Pulse #1 Cylinder Built into the fuel injection control unit is logic that will shut off the #1 injector if the computer believes that it can no longer control the Idle Air Control Valve. Remember this design characteristic if you are trying to diagnose a “hard” code for the Idle Air Control Valve or a dead miss in the number one cylinder due to no injection at idle. A problem in the Idle Air Control Valve circuit may be responsible. (Component testing shows that it most likely is not the valve itself.) Also, if the computer is deprived of its “back up power supply,” some computers will generate a false code for the Idle Air Control Valve and kill the injector End Wrench 14 End Wrench The for cylinder #1. The pin location of this power supply can be found in the Control Unit Module I/0 Signal pages of the appropriate Service Manual." http://www.northursalia.com/techdocs/pdf/engine/emissions.pdf So would this interruption to the battery back up power supply to the ecm cause a misfire or no pulse to the #1 injector, what is the best way to maybe circumvent this issue?
May 14, 201510 yr I had a 99 sus and did same swap. 96 2.2 and all. I thought a 99 legacy sus or outback had a one year only ecu because of the phase 2 trans and phase 1 engine electronics ah - i'm unsure of that 99 deal. this thread suggests they're the same but they're not talking about 99's specifically.....but fairtax and bratman know their junk, maybe they'll see this.
May 14, 201510 yr Check voltage to the #1 injector. Need to know if its not working because the ECU is not commanding injection or if there's a wire issue. The article above seems to indicate the problem will only occur at idle if the computer is cutting injection pulse. Does your misfire go away if you rev the engine up? Have you checked to make sure all the electrical plugs on the bellhousing are tight? The main ECU ground connection is on the intake manifold, make sure that's clean and tight.
May 16, 201510 yr Author car fired up fine, after reading the article we came to the conclusion that the battery just needed to be replaced, we replaced the battery. ran great yesterday, started the car today after putting on some engine degreaser to clean the motor, now im back to square 1, as my luck would have it. the new engine is knocking something fearce , i think i may have pissed off the Subaru gods or something.
May 17, 201510 yr That engine has hydraulic lash adjusters and they will clatter like the end of the world if they bleed out. Use a stethoscope and see if the noise is comiing from the heads. If it is, pull the valve covers and remove the rocker shaft assemblies. The feed port in the rocker shafts and tiny and easily plug up with RTV/or other crud, usually after someone has resealed the oil pump. Blow the rocker shafts out with compressed air, pump up the lifters with fresh oil and re-install.
May 17, 201510 yr Author i took a stethescope to each head then to the oil pan, its really loud at the oil pan,
