May 18, 201510 yr I have a '92 SVX with sunroof that slides open but not quite closed. Stays open about 1.5 inch. If i hold the button down I still hear motor turning. I cleaned tracks with WD 40, paper towels and cotton swabs doesn't move any further. Also lubricated linkage at back of sunroof. When it comes to a stop its a definite stop. Feeling the panel as it closes the stop seems to be on front driver corner. Any suggestions? Diagrams of this mechanism?
May 18, 201510 yr I had the same problem. Had to hand-assist the sunroof closed. If you have an air compressor and nozzle, that helps clean the tracks. I used Liquid Wrench for lube. It works great now.
