May 23, 201510 yr Ok, belt is on, all idlers in place and the new tensioner. all the marks did line up when I put the belt on (belt marks) but now they are off by 1 or 2 teeth, but that appears to be consistent. I figure it shifted down at the water pump cogged idler. Just want to make sure this all looks right before I put the covers on and go put the engine in. First set of pictures: Second Set:
May 23, 201510 yr Looks good to me. Rotate the crank twice and make sure they all line up again. Ignore belt marks because they're useless.
May 24, 201510 yr find the tooth count for your engine as a double check. belt marks only line-up again after dozens of rotations.
