'87 Subaru Libero Engine Swap
Hi subaru folks, I just adquired an '87 Subaru Libero, and apparently the engine block is cracked, so I tryed to find the same engine on my country's (Spain) but since I imported the car from Germany and this car wasn't sold here, there is no chance to find one here. I goggled a little and it seems that this engine ,E12, is the same 1.2cc 3 cyl. block than the used at the Subaru Justy, wich was sold in Spain, I found some of those engines from wrecked cars, but I have some doubts here that you may solve:
-The engine codes I found were EF12 instead E12, apparently its all similar, naturally aspirated, carburator, no electronic engine management, so no ecu, etc, but; I would like to know if my gearbox housing is the same, and if I would find any problem with the starter pinions/ring or the cranck size/pinions, etc. Aswell, this EF12 has around 20 more hp, and im guessing if that would cause any issue on the Libero's gearbox. Thx.
According to the car's title, the engine is the KJ8 type...is it a different code for the same engine E12?
  • 3 months later...
