June 12, 201510 yr Hello; Fuel Pump Question; Subaru Loyale 1994 - 1.8 TBI Are the AirTex E8059 "Replacement" Fuel Pumps Correct; for the high pressure needs of the TBI on the 1.8 Subaru Loyales...!? Or are these for carbureted models Thanks in advance! vtscooby
June 12, 201510 yr No,those are for carbs. Then again,it is what they list,but,they also say maximium psi = 3 psi (not enough) It looks correct(not like a carb one that has a different part #) I think there is a problem with thier application listing or information, Edited June 12, 201510 yr by naru
June 12, 201510 yr Sure looks like the right pump to me. http://www.amazon.com/Airtex-E8059-Electric-Fuel-Pump/dp/B000ZN2CEY
June 12, 201510 yr Author What is the Best Option for "Factory Style" High Pressure Fuel Pump Replacement?
June 12, 201510 yr The Carter crosses over to the correct Subaru#,42021GA242. I think the Airtex is correct too,despite them stating it is only 3 psi. I think the 3 psi is an error.I`d chose an airtex over a carter,but,the stated 3 psi would scare me too. The airtex crosses over to the correct one as well.
July 5, 201510 yr Author YES!~ the Airtex E8059 Fuel Pump; Does work on the Throttle Body Fuel Injected 1994 Loyale!~ This appears to be the correct "high pressure" fuel pump!~ Thanks for all of your help!~ Best Regards
