vtscooby Posted June 12, 2015 Share Posted June 12, 2015 Hello; Fuel Pump Question; Subaru Loyale 1994 - 1.8 TBI Are the AirTex E8059 "Replacement" Fuel Pumps Correct; for the high pressure needs of the TBI on the 1.8 Subaru Loyales...!? Or are these for carbureted models Thanks in advance! vtscooby Quote Link to comment Share on other sites More sharing options...
naru Posted June 12, 2015 Share Posted June 12, 2015 (edited) No,those are for carbs. Then again,it is what they list,but,they also say maximium psi = 3 psi (not enough) It looks correct(not like a carb one that has a different part #) I think there is a problem with thier application listing or information, Edited June 12, 2015 by naru Quote Link to comment Share on other sites More sharing options...
vtscooby Posted June 12, 2015 Author Share Posted June 12, 2015 What about the Carter P72081- Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted June 12, 2015 Share Posted June 12, 2015 Sure looks like the right pump to me. http://www.amazon.com/Airtex-E8059-Electric-Fuel-Pump/dp/B000ZN2CEY Quote Link to comment Share on other sites More sharing options...
vtscooby Posted June 12, 2015 Author Share Posted June 12, 2015 What is the Best Option for "Factory Style" High Pressure Fuel Pump Replacement? Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted June 12, 2015 Share Posted June 12, 2015 The specs are probably incorrect. Some listings show 50-70psi some say 1.5-3 Quote Link to comment Share on other sites More sharing options...
naru Posted June 12, 2015 Share Posted June 12, 2015 The Carter crosses over to the correct Subaru#,42021GA242. I think the Airtex is correct too,despite them stating it is only 3 psi. I think the 3 psi is an error.I`d chose an airtex over a carter,but,the stated 3 psi would scare me too. The airtex crosses over to the correct one as well. Quote Link to comment Share on other sites More sharing options...
vtscooby Posted July 5, 2015 Author Share Posted July 5, 2015 YES!~ the Airtex E8059 Fuel Pump; Does work on the Throttle Body Fuel Injected 1994 Loyale!~ This appears to be the correct "high pressure" fuel pump!~ Thanks for all of your help!~ Best Regards Quote Link to comment Share on other sites More sharing options...
