Difference between EJ202 and EJ20E
Hi!
I have a question: I'm thinking about buying a Subaru Forester MY98 or MY99 with a broken engine and replacing it. Now I found out that the Forester uses EJ202 engines instead of EJ20E used in Legacy and Impreza. What's the difference? Can I put in an EJ20E without changing the original ECU? There are many old and cheap EJ20 Legacy out there with working engines just rusting away so that would be a perfect swap...
Oh, to clarify: In Germany the Forester was offered with a 2.0 L engine (like Australia), not with 2.5 L like in USA.
Thanks!
The biggest difference as it would matter to this application is that the ej20e is phase 1 and the ej202 is phase 2. They are not electronically compatible, you will need to find another phase 2 ej202 to replace yours.
Ah OK. Now I got it :) Phase 2 was used starting with MY99? So a Forester from 1998 or early 1999 should have a Phase 1 EJ20?
It was MY99 here in the US, I'm unsure if that was true worldwide as our model year guidelines are slightly different. What the Japanese and Australian market calls a 99 Legacy is what we call a 00. The phase 1 and phase 2 sohc engines are easy to distinguish from each other though. Phase 1 sohc motors have the head bolts and raised ridges on the valve covers, phase 2 sohc engines have larger smooth valve covers that hide the head bolts.
