July 14, 201510 yr as far as i know yeah, only 1, its by the shock tower above the brake fluid reservoir. i changed mine from the original to a WIX branded one in june 2014, so far so good.. (knock on wood) Edited July 14, 201510 yr by Subasaurus
July 15, 201510 yr If it's still got the factory fuel pump, there's also a strainer sitting inside the inlet (to catch stuff that might be in the tank), but it's not replaceable. Just take the pump out & clean it. If there's an aftermarket pump, make sure there's a filter between it & the tank. Edited July 15, 201510 yr by wagonist
