August 2, 201510 yr on my 2006 impreza i was driving home from the dealership and my abs light came on i am going in tomarrow to make a payment maybe they can check it out and find out why the ac doesn't work and the cruise. for 7,000 bucks it should run better than that.
August 3, 201510 yr was some work done? what? could be a sensor at a wheel (bad, loose wire, or covered in debris, or cheap/wrong new wheel bearing etc.) - weak charging might also set ABS. a/c is sometimes just 2 o-rings and schrader valves plus a new charge of refrig. is the CEL on? that will kill cruise on all newer model cars. good luck
August 5, 201510 yr Author i checked the oil it was a little over got the cel to go off for a while but now it is back the abs never did go off shouldn't the lot fix that? the ac just needed a belt.
