Getting doors off
'86 Brat
Is it easy to get the doors off? Just pop the pins up from the bottom?
You have to unbolt the hinge from the door. It's important to NOT remove the hinge from the car if you can in order to maintain the alignment of the door. It's tight, but not real hard with a small socket wrench.
its best to remove the fender first to get to the door hinge bolys. you will see where its painted to line it back up when you put the door on. any wiring to the door will connect behind the kiclk panel near the floor. it just pops up, and you will see a green, white and pink connectors. the pink will be for power windows, the white one will be for the speaker
there are 2 10mm nuts behind the bumper trim to remove the fender
