Loyale - Tachometer Inop
Started my Loyale this morning and the tach isn't working.  Cant find anything in my Chilton manual about it.
Anyone have experience with this?
try unpluging and pluging back the main harness that goes to the engine, theres 2 big plugs behind the battery, under the spade terminal fuses between the engine and frame "rails" on the driver side. i had an issue where my rpm's (tachometer) would just stop at 2,500 like it was stuck, and would work again once i was below 2,500. it might just be a bad connection since theres so many connections inside that plug.
try doing that first, it fixed my issue..
