August 21, 201510 yr Just wondering what year the EA81 changed from solid front disc rotors to vented in the US market. I was once sold pads to suit solid for my 10/84 EA81 Brumby, turned out I needed next pad along. Figured my ute was made for MY85 and maybe that is when they started vented, or the sales dude just screwed up, or someone upgraded vented discs and later calipers to replace solids on mine - DB426 (D291 US numbering). Hmm, also wondering if the caliper changed with the rotor change, or just the brackets changed and use same caliper ? Mmm...no wonder ..am looking at a Bendix catalogue 1800...............4WD............................1980-83...front...DB326 (D189 US numbering) Brat.................AU2,5................1982-83...front...DB326 ........................DL,GL.........................1981-84..front...DB392 ( no us type number in cat) ..........Turbo fwd hatchie...........1984-86..front.....DB426 Brumby.......pick up.............................1981-84...front....DB392 ................pick up 4WD.............1982-85...front...DB326 ..............pick up 4WD..........................Mar 85-94...front..DB426 .............utility............................1979-80 ....front DB112 so, looks like Bendix think Brats came out in non 4WD ? Not sure the difference between a pick up and a utility is either Edited August 22, 201510 yr by jono
August 22, 201510 yr 83 for 4wd automatics. 84 for all calipers are different The difference between a pick up and a utility is the year. in this listing. Up to 80 they call them utes,after that Brat/Brumby or pickup. 4wd refers to cars
August 22, 201510 yr Author aha, is sort of self explanatory, so calipers are different and not just a bracket change then ...thanks naru Looks like Bendix not in the UK or otherwise we would also see MV or MV1800 in the listings
