September 6, 201510 yr Hi all, The pneumatic suspension has been removed and replaced on my 93' Liberty by the previous owner because it has been proven that the system is expensive to maintain and unfortunately tends to leak a lot. The suspension that is now fitted rides a little to high for my liking and aesthetically looks weird. The car at high speed doesn't feel as safe as it should ect, ect. Ideally i'd like to lower the car to make it more stable and feel stronger, but is it to expensive to worry about? Any idea and advice around this issue would be much appreciated. Thanks.
September 6, 201510 yr A used set of struts for a lower trim package without air suspension is probably the easiest fix
September 6, 201510 yr A used set of struts for a lower trim package without air suspension is probably the easiest fix I seem to remember coil springs at the struts. Shorter coil springs will also help to lower the heighth.
