September 11, 201510 yr The rubbery trim that goes from the top of the door to the window on my Soob is cracking and breaking off. I had thought about trimming it on the part going to the door, and then using Flex Seal and tape off a strip to cover where the part that was trimmed off was. Not sure if this trim is still available. Thoughts?
September 11, 201510 yr i have an 89 GL that was cracking also, stole one from a junk yard vehicle, fixed that issue. but you might want to say what generation your vehicle is? Update: you have an 86 XT. don't know much about the seal/trim, someone here can probably answer. Edited September 11, 201510 yr by Subasaurus
