Removing Intake Runners Complete, Procedure?
Hi Forum, I need to remove my complete intake to access coolant manifold on a '94 Legacy ej22, easy? Any special procedure or other required? Thanks!
fairly straight forward - just remove all the stuff in the way - plug wires, throttle cables, hoses, disconnect CTS wires under manifold and i assume oil pressure sender too under alterantor.
Thanks! I have been reading about removing hard fuel lines and replacing with soft which cleans up things quite a bit, might do this as well
