gbowne1 Posted November 22, 2015 Share Posted November 22, 2015 trying to figure out one of several things.Vehicle:1995-1997 Subaru Legacy Wagon L w/AT & ACCondition: KeyOn EngineOff Self TestBeeps / chimes: 5 timesThese bulbs are all still on after system/bulb test completes:Check EngineAT Oil TempOilBatteryBrakeWhat could be going on here?? Recently had a P0400 code. needed some EGR/ BPT work. Code Cleared. May still have clogged pipe(s), head, etc. CEL (nor do any of the others) do not appear after the engine started. Recently had a Drain & Refil of Dextron III ATF Brake Master Cylinder replaced recently. Front Brakes 25% (4mm) Rear: 7mm Other work that needs done: Rad Hoses all belts Front brakes Axle Boots Power Steering Pump rebuild (leaks) minor engine leaks (needs new gasket set) Quote Link to comment Share on other sites More sharing options...
matt167 Posted November 22, 2015 Share Posted November 22, 2015 those lights lit, key on engine off is normal Quote Link to comment Share on other sites More sharing options...
gbowne1 Posted November 22, 2015 Author Share Posted November 22, 2015 I have had others ('95 Legacy Sedan) where in this mode, they were off KOEO. With the exception of Batt. (weak battery & alternator). Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 22, 2015 Share Posted November 22, 2015 Thats perfectly normal. Those lights stay on until you start the engine. Quote Link to comment Share on other sites More sharing options...
