RandyWayne Posted November 30, 2015 Share Posted November 30, 2015 I'm in the process of swinging a motor into my daughters 08 legacy. she paid a little extra for the low miles trans that is bolted to her new low miles motor from an 09 impreza. the trans id numbers are very similar except for one digit. 08 legacy trans - TZ1B8LC4BA 09 impreza trans-TZ1B8LCEBA what is the difference? there are also some electrical differences. the 08 trans has a sensor on the tail shaft and a screw in filter. the 09 does not. it does have bosses for them though. it looks like it plugs right in but I dont know if it will work. the shift selector switch is different as well. but has what looks like the same pigtail. is the 08 tailshaft sensor is the 08 select switch is the 09 switch is the 09 tailshaft housing with boss, without sensor. I guess what im asking is, can i use the 09 trans? and what do i need to change to use it? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 1, 2015 Share Posted December 1, 2015 My main concern would be if the final drive ratios are the same. Quote Link to comment Share on other sites More sharing options...
RandyWayne Posted December 1, 2015 Author Share Posted December 1, 2015 I did a ton of research on that first. and as far as I can tell, they are the same. then I saw some info on whats called "dynamic drive" or something colorful like that. it seems that might be the difference in the two transmissions. Quote Link to comment Share on other sites More sharing options...
