ragingbull Posted December 6, 2015 Share Posted December 6, 2015 In the middle of my swap 86 Brat 4 speed to 5 speed and I can't find it anywhere online. 4wd lever is needed too. All help appreciated! Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 7, 2015 Share Posted December 7, 2015 Use the 4spd stuff and customize it to work. The 5spd stuff won't fit without cutting in the brat. Quote Link to comment Share on other sites More sharing options...
wagonist Posted December 7, 2015 Share Posted December 7, 2015 usually, you cut the linkages, shorten to suit & then weld back together as they push the linkages in the same way despite the 4wd lever working the opposite direction. Quote Link to comment Share on other sites More sharing options...
ragingbull Posted December 8, 2015 Author Share Posted December 8, 2015 Thanks guys! Looks like the linkages are totally different from the 4 to 5 speed.. IL try to rig something up as I can't even find the shifter for the 5 speed. Quote Link to comment Share on other sites More sharing options...
wagonist Posted December 8, 2015 Share Posted December 8, 2015 The way the linkages work on the back of each gearbox are the same though, so you can get the 4 speed stuff to work on the 5 speed, you just need to adapt the ends. I've never had the 4 spd though, so I don't know if the 4 spd linkages will physically fit onto the 5 spd trannie. You'll need to do a test fit. If you really get stuck, I can send you some linkages from over here. Quote Link to comment Share on other sites More sharing options...
