stuck piston
good day all
its been a long time...
l'm visiting a a friend and naturaly her car needs work....
it's a 96 legacy l
driver side brake caliper is stuck
(has been for a while judging by the diferential wear on the pads
don't have a shop at my disposal here --
how do l un-stick the piston?
or do l just replace it?
thanks
goat
Edited by goat
The simple way with the simplest tool set needed (and quickest too): replace caliper, pads, and rotor and be done with it. Who knows what wear issues you have with that rotor and you can probably buy a new one cheaper than getting it turned.
that's what l figured...
prefer to rebuild things -- rather than just replace
but not this time
rotor looks fine...
thanks
goat
have you pysically taken it apart?
it's usually the slides that are stuck - not the piston.
clean and regrease the slides with high quality grease like SilGlyde, it's 100X better than the regular permatex stuff.
if it's the piston you have a couple options:
1. unbolt the caliper from the caliper bracket
pump the brake pedal...starting lightly then harder and see if you can get any piston movement via the hydraulic pressure of the brake system
if it moves - then compress/extend/compress/extend
2. alternately you can just push the brake pedal until the piston comes all the way out of the caliper - fluid and all.
then rebuild it - rebuild kits are like $3 - $10 and include a new seal for the piston.
real simple.
if the piston is rusty it'll need replaced
3.  get another caliper.
yeah l took it apart
the slides are ok
piston won't comprest...
haven't tried pumping it out
cuz this is the only car available for driving to the auto parts store...
guess I'll buy a caliper
and a rebuild kit
return the one l don't use
thanks
goat
if something goes wonky you can drive the car with just the emergency/parking brake.  CYA legal disclaimer - i don't recommend it because it's unsafe, probably illegal, etc.
but i've done it a bunch of times - choose time of day and route appropriately and i haven't had a problem.
gross Gary
like your style
done that before as well
most notably in a school buss...
but the car in question is at the top of a long and steep and rutted and windy dirt road
and it's been raining for days...
anyway --
l got the piston out
and could have rebuilt it
but the useless employes at the Mckrankin
franchise
couldn't find or didn't have a rebuild kit
and the seal got damaged in the extraction
so there's a new caliper on there
(and the other side got its sliders greased -- which it needed badly)
did l mention it was raining
and l was in a dirt (that is mud) drive way
what fun ;)
thanks for the help
goat
