February 2, 201610 yr ive had an exhaust leak from the front flange since i got the car ive tried to fix it a few times now with no success new gasket double gaskets whats the best way to seal the flange when a gasket wont seal it? this is the last leak left in my exhaust. Edited February 2, 201610 yr by sirtokesalot
February 2, 201610 yr I take it you are talking y-pipe to Cat? Take it a part and inspect it. You can grind any high spots down, bend the tabs until they pull well. If you get it flat a single gasket should work.
