1999 OBS Drivers Window?
I got it adjusted for the upper stops just fine, but when it opens all the way in auto, the motor drive gear jumps the teeth.  I forget what stops the motor drive going open.
I thought there was a chunk of some sort on the regulator that keeps it from rolling open too far.
Could be wrong, I haven't messed with a Subaru window in a while.
Thanks, I'll pull one at the yard when I get time.
Yep. There is a stop at the bottom of the travel.  The one on mine is plastic.
  • 1 year later...
I replace the window regulator today.  Works great.  I could see the motor jumping the regulator teeth on the old one.
Works great.
