N/A EJ Swap question, fuel system Q!
What do I need to do with my fuel system in my carburated L-Series so I can run the N/A 2.0l EJ motor?
I know that I cannot use the carb fuel pump, could I use the fuel pump from a Loyale SPFI? Or maybe a EA82T pump?
I have a Walbro 255lph that goes in the car when my turbo EJ motor will be ready next year but I'm doing a N/A swap first so I can fix everything this year that needs to be fixed and do my 5x100 swap and suspension and I want to have the car running whilst I fix it.
If you have the Walbro, seems easiest to just swap that in. It'll be overkill, but that's fine.
Stock SPFI pump works just fine for an N/A EJ.
Make sure you upgrade all the pressurized rubber fuel lines, too.
Thanks man. I appreciate the time you take on answer the threads on here. See your posts in all the EJ Q threads. I also have your pdf in my phoe and my computer ;)
So if I just put the walbro in straight away it wouldn't ve a problem, good. So I'll do that and change all the rubber lines. Should I just get regular rubber fuel lines or braided steel ones?
Yep, EA82 pump is under the car near the RR tire.
Rubber Fuel Injection line is perfect.
