mkc1962 Posted March 22, 2016 Share Posted March 22, 2016 I recently did a refresh of the engine on my 82 Brat. Part of this was to have the heads reworked and surfaced. After an initial break in of about 100 miles, a few days later put it up on the lift and noticed a coolant weepage from both heads in the same location (pic attached) . Ive done hundreds of heads in my day and never any sort of leekage. But, this is my first subaru engine. Is there maybe some sort of special oring or sealant needed at some spot within the head gasket? I did not notice any such during disassembly, and was not leaking in that area prior that I coudl tell. I Followed fsm guidlines but saw no such comments about sealing this area in any special way. Ive retorqued the heads, and no improvement. Used Felpro Head gaskets and OEM intake gaskets. No leakage from above dripping down and over. Has anyone seen similar before? and if so any possible feedback is appreciated. Quote Link to comment Share on other sites More sharing options...
Len Dawg Posted March 22, 2016 Share Posted March 22, 2016 Possibly something stuck in water passages in the head if they were sent out to be worked on ? Or the incorrect style of head gaskets, that my geass.. let us know.. Nothing worse than a dead end thread... Quote Link to comment Share on other sites More sharing options...
mkc1962 Posted March 22, 2016 Author Share Posted March 22, 2016 I thoroughly cleaned them upon return as well as a good flushing of the cooling passages on the block. I used the Fel pro spec'd gasket for the application. No holes that were in the block or head was not present on the gaskets. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted March 23, 2016 Share Posted March 23, 2016 The drip-points shown are just the lowest spot that coolant will run to before it grips off. I don't recall the name of the stuff at the moment, but there's a dye you can put in the cooling system that shows up under a Black Light. Quote Link to comment Share on other sites More sharing options...
mkc1962 Posted March 23, 2016 Author Share Posted March 23, 2016 Yes I have the UV die test kit. Have not used it on this engine yet. But this is a Clean fresh rebuild, All new seals, gaskets,hoses, etc. no leaks are immenating from above and wicking down and over, trust me that is the first thing I checked. This is weepage coming from this area on BOTH cyl heads. I had really hoped it was just an issue of both heads needing a retorque after a rebuild. But that was not the case. I retorqued both last week.Thoroughly Cleaned up any and all residue, then took it for another 50 mile drive, back up on the lift, and once again all 4 of those low points (both heads) had coolant dripping from them. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted March 23, 2016 Share Posted March 23, 2016 I would do the dye anyways. You have it already, so it's not an extra cost. Quote Link to comment Share on other sites More sharing options...
mkc1962 Posted March 24, 2016 Author Share Posted March 24, 2016 Probably will this weekend. Have been working over all week and no time for shop play. Quote Link to comment Share on other sites More sharing options...
Kristina Posted March 24, 2016 Share Posted March 24, 2016 +1 on the dye. I thought I had a headgasket issue until the dye showed it was leaking out of the turbo hoses then dripping down all over the place. It might not help in your case, but it definitely won't hurt either. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted March 24, 2016 Share Posted March 24, 2016 Probably will this weekend. Have been working over all week and no time for shop play. I can so relate to that!! Quote Link to comment Share on other sites More sharing options...
mkc1962 Posted March 29, 2016 Author Share Posted March 29, 2016 grrrrr.....weekend die test shows only presence of coolant to be right where its weeping. I think I'll give it a bit more run time to see if it will eventually stop due to the recent retorque, but does not look promising. I guess next good weekend off, will plan on pulling the heads again, new gaskets and maybe a tad of the gray stuff around those holes that flow coolant in that area. Not a fan of doing that though. Quote Link to comment Share on other sites More sharing options...
