March 30, 201610 yr I'm looking for a pair of 21091GA190 springs. Although people list availability, when I order, the order is refunded with the part out of stock. I used a pair of cut down 1995 Ford Tempo springs for the front and they are perfect. Anybody using any alternates for the rear?
March 30, 201610 yr Yea, that part number is discontinued, and I did a search of dealer inventory, and none with 5000 miles of here in Northern MN, shows any inventory. It also looks like that number is for a 2WD car... They are 2.5" ID springs, which happens to be the most common size for coilover springs. They can be had from many suppliers in many lengths/spring rates for fairly cheap. I think, off the top of my head, that most EA82 rears are about 190 lb/in springs. I have definitely used 250 and 275 lb/in with good results. I think I'm running a 10" 250 Eibach in the rear of my XT6 right now (I'll try to remember to check later tonight when I'm working on it....if the stamping is still legible).
March 31, 201610 yr I did remember to check, and the stamp was still legible. 12" long, 250 lb/in springs, on KYB GR2s for a 4WD EA82 wagon, with stock upper mounts: This gives a slightly taller ride height, and matches my stock WRX front springs very well.
