Flat4Power Posted April 27, 2016 Share Posted April 27, 2016 Where do I get good pistons for my ej22 rebuild project? Quote Link to comment Share on other sites More sharing options...
Flat4Power Posted April 27, 2016 Author Share Posted April 27, 2016 I'm still wondering about this actually. There are small scuffs on the tops side of the piston skirt but other then that they seem to be fine. Should I bother replacing them? Cylinders look like new.... Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted April 27, 2016 Share Posted April 27, 2016 I've not seen any stock replacement phase 2 ej22 pistons on the market. Only thing available is oem, and they are not cheap. The rings for those pistons are also only available from the dealer. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 27, 2016 Share Posted April 27, 2016 They're all over ebay. Also, NPR is the co. which makes them for Subaru. We've always used them and they are top quality. OTOH, Mahle brand make our head builder just go nuts: they're impossible to work with. However, with your description, I'd just re-use them. Put them back in the cylinders they were in originally. Emily Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted April 27, 2016 Share Posted April 27, 2016 Phase 2 ej222's don't use the same pistons or rings as the 90-98 ej22e. 99-01 ej22 rings are 1.2mm/1.2mm/2.5mm, 90-98 ej22 rings are 1.2mm/1.5mm/3mm. Quote Link to comment Share on other sites More sharing options...
Flat4Power Posted April 28, 2016 Author Share Posted April 28, 2016 Thank you. I'll just give the dealer a call and see how much...the prive is probably gonna blow my mind isn't it...? Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 28, 2016 Share Posted April 28, 2016 Rings: http://www.ebay.com/itm/Engine-Piston-Ring-Set-DNJ-PR719-fits-99-01-Subaru-Impreza-2-2L-H4-/161806428020?fits=Make%3ASubaru&hash=item25ac6a2774:g:5oQAAOSwjVVV3geL&vxp=mtr Seriously, from your description, there is no reason not to re-use the pistons. Emily 1 Quote Link to comment Share on other sites More sharing options...
Flat4Power Posted April 29, 2016 Author Share Posted April 29, 2016 I agree, I meant to say just for the rings. I called today....$270 Canadian for a set of rings yikes. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 29, 2016 Share Posted April 29, 2016 Yeah, dealer is NOT the place to buy rings. That blue and white box equal about a 1000 % markup. Try an import store, or ebay. Emily Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 30, 2016 Share Posted April 30, 2016 NPR rings on eBay are like $50. Only place I would consider pistons other than the dealer would be a custom order from one of the performance piston makers like Wiseco. Gonna spend a big chunk more for those than getting new from a dealer. The cheaper ones are a crap-shoot. 1 Quote Link to comment Share on other sites More sharing options...
