July 2, 20169 yr 99 Outback - I might be losing my mind - I cannot locate the dipstick. According to the owners manual it should have a yellow ring and be towards the rear of the engine block on the right side. - Any ideas to locate? - thanks
July 2, 20169 yr I have a 99 OBW, seem to remember it sits low on the passenger side near the firewall. I don't remember a yellow ring. The dip stick is small, with what I remember a finger loop to pull out the stick. Stick is only about 3-4 inches long. Not anything as obvious as the oil dip stick.
July 2, 20169 yr Author Opps - My mistake - it should read: Location of Automatic Transmission Fluid Dipstick - Sorry - Thanks, Captain Jack
July 2, 20169 yr Opps - My mistake - it should read: Location of Automatic Transmission Fluid Dipstick - Sorry - Thanks, Captain Jack It is located at the fire wall on driver's side. The dip stick handle is hidden under hoses and cables. Using your hand, mover them out of the way, so you can reach through them. Good idea to use a flash light to look down into that dark area. Yes, I think it does have a yellow handle. My dip stick handle always seems stuck, and difficult to pull out, so don't be surprised if you have to pull hard to extract it from it's circular tube encasement.
July 2, 20169 yr On mine it had a small yellow ring tab, like big enough for your pinkie. It was near-ish to the brake fluid reservoir as a landmark but yes having to kind of reach down in there maybe 6-8 inches below hoodline. It you don't see it, it is possible it is missing, like someone removed it and didn't put it back for some reason.
July 3, 20169 yr Front diff fluid on the the right side. Sticks out just behind the bellhousing a little above the axle. Auto trans fluid is on the left side below/behind where the heater hoses stick off the back of the engine.
