dp213 Posted August 3, 2016 Share Posted August 3, 2016 I need to replace an engine in a 90 loyale. Someone else tore the motor apart and I don't have the intake. What I'm wondering is, are the TBI mfi long blocks interchangeable? From what I have read the car could have either one. I will have the original intake tomorrow, I just need to find a good motor and am hoping I can get either long block and use it. Thanks Dp Link to comment Share on other sites More sharing options...
DaveT Posted August 4, 2016 Share Posted August 4, 2016 IF you are looking at SPFI 1800 EA82 engines, the block and heads from 87 t0 93 are the same. There were variants of the heads, but it's minor internal stuff that doesn't effect using them. I've swapped engines between 86 and 93, by changing the intake. if I needed to due to harness differences. There are some different connectors used, but all the same sensors / functions. Link to comment Share on other sites More sharing options...
dp213 Posted August 4, 2016 Author Share Posted August 4, 2016 Very cool, so it's basically like putting a 95 ej22 in place of a 98 ej25, which is a very easy swap that I have done many times. Link to comment Share on other sites More sharing options...
dp213 Posted August 4, 2016 Author Share Posted August 4, 2016 Ot even a user comparison is using a 93 ej22 and putting the 95 ej22 intake on it. Link to comment Share on other sites More sharing options...
dp213 Posted August 4, 2016 Author Share Posted August 4, 2016 Wow, auto correct sucks????. That was supposed to say, or even a closer comparison Link to comment Share on other sites More sharing options...
dp213 Posted August 8, 2016 Author Share Posted August 8, 2016 So I have a line on a mpfi motor from a 1989 xt. It has low miles on it, but he said it dies when in get warmed up. Will the spfi intake from the 90 loyale work on that motor Link to comment Share on other sites More sharing options...
DaveT Posted August 8, 2016 Share Posted August 8, 2016 I am not certain, but I think the mpfi heads and intake are different? Link to comment Share on other sites More sharing options...
dp213 Posted August 8, 2016 Author Share Posted August 8, 2016 The intake probably is, I just don't know about the heads Link to comment Share on other sites More sharing options...
DaveT Posted August 8, 2016 Share Posted August 8, 2016 Looking at the sketches in my 86 fsm, the intake and heads look different between spfi and mpfi. Not interchangeable. Passages and bolts won't line up. I've never had a mpfi so I could be missing something. The spfi manifold / head meet with 3 bolts. There is a small odd rectangular coolant passage inboard. One round air passage outboard. The mpfi kind of looks like it has 2 passages for the air. The sketches are not highly detailed. Link to comment Share on other sites More sharing options...
dp213 Posted August 11, 2016 Author Share Posted August 11, 2016 Are the carbureted motors changeable to spfi Link to comment Share on other sites More sharing options...
DaveT Posted August 11, 2016 Share Posted August 11, 2016 I did take my carbed 86 block and heads, and bolt on a spfi manifold, and it worked fine. I put the engine into a newer spfi body, so it wasn't a conversion, it was an engine block swap. The spfi manifold was the one in the car that needed the swap. So it would be like what your original post is. 1 Link to comment Share on other sites More sharing options...
