December 12, 20169 yr Hi I have a 1984 dl 4 door sedan 1.6l ea 71 manual trans When I bought the car it ran great for 2 trips to work it then began bucking and kicking while accelerating and cutting out completely then would be hard to restart. I gave it a tune up cap rotor plugs air cleaner. Did not fix it changed both fuel filters and threw a fuel pump at it just for the hell of it. Still the same I've attempted to read the codes it had a code 13 one long blink 3 short at first but has changed to a code 33 3 long blinks 3 fast. I'm not sure where to go now I believe I found the fuel pump relay under the passenger seat I've swapped them around didn't change anything it will start and idle for some time then will cutt off sudenly.
December 12, 20169 yr I did a quick search of this forum for code 33 because I know nothing about it. I found this which may help: http://www.ultimatesubaru.org/forum/topic/129661-cut-out-problem/?hl=%26quot%3Bcode+33%26quot%3B&do=findComment&comment=1102545 If you do the same search you will find several topics have been posted. Perhaps one which is similar to your own.
