December 19, 20169 yr Hello to all, I've recently acquired a VW bus conversion with a 1998 EJ22. I don't know much at all about the Subaru world, but I'm ready to learn. Is this an OBD I, or OBD II? Do I need to submit more info? I'd like to add some type of readout to the dash for the engine operating parameters, other than a bunch of steam gauges, any help or info would be greatly appreciated, thanks.
December 19, 20169 yr Welcome to the forums, mate. Hopefully you'll find the info you're after. The picture you attached (or is it apart of your signature?) is tiny, you may want to add a higher resolution picture.
January 3, 20179 yr I believe people use the Scangauge product to see 'real time' engine parameters...assuming this is running the stock '98 EJ22 ECU as well.
