Aww.. yer bummed your rear window latches are broken... Interest Post
Greetings!
Several years ago I was approached about making a replacement for the rear window latches on EA81 hatches.  I made a couple of batches while I had access to the equipment to do so.  They worked out well and I've been approached about whipping up another batch.  So, here's a call out to see who is interested.
How it works,
You ship me your busted latches as a core, all the steel bits have to be there.  I take your metal bits and mount them in the aluminum (6061-t6) handle that I'll be making.  I assemble it, I can sandblast the steel hardware for those that want to repaint, then send it back to you.  Shipping overseas is fine, but maybe cost you a bit extra depending.
Price is $65 for a pair.
Assembly is pretty straight forward, so an alternative is that I just ship you the handles and you put it together yourself, up to you.
Here's a pic of the handle with hardware installed.  Also a link to the Vendor forum where you should place your order.
Cheers,
Will-
https://www.slickpic.com/users/WillMorton/albums/Port/photo?view=10933303&fullsize#10933303
http://www.ultimatesubaru.org/forum/topic/161862-replacement-rear-window-latches-for-ea81-hatch-and-justy/?p=1346518
Will, you should post this in the historic forums, more ea81 in there.
Wow, the EA81s are 'historic' now?  Damn, I feel old.  I have't been active on the board the last few years, things do change.  Thanks for the tip I75eya
Historic section still only applies to the 70's cars last time I checked.
I checked and that appears to still be correct.  I suppose these latches might work on historic models, dunno, never owned one
My mistake! That's what I get for shying away from here for so long! I forget!
actually I think the 80-84 subies are probably better grouped with the historic forum. The pushrod era. OHV represent!
