compression test numbers?
I recently tested my cylinders in my Loyale with a SPFI EA82
the PSI I recorded was
Cylinder 1 - 150 PSI
Cylinder 2 - 140 PSI
Cylinder 3 - 140 PSI
Cylinder 4 - 135 PSI
I,m looking for the proper PSI for this engine so I can compare it with recordings that I took.
If anyone knows the specifications I would greatly appreciate it.
That's a 9.5:1 engine. Ideal numbers at sea level would be 190 psi.
But the number isn't important as much as the difference between highest and lowest. Ideally you want less than 5% difference between high and low.
It's most likely low due to valve sealing. Probably needs a valve lap/grind.
G
thanks for the info! ''general disorder''
