April 19, 20178 yr Looking for help got snagged ,,did the heads and valves all gaskets,,looking for someone to explain how to time it .From the distr, cams. and the crank.Engine is still on the bench.
May 12, 20178 yr A lot more people would see this in the older generation forum. There are lots of threads and links and explanations there.
May 12, 20178 yr Looking for help got snagged ,,did the heads and valves all gaskets,,looking for someone to explain how to time it .From the distr, cams. and the crank.Engine is still on the bench. Please search USMB for info on subject first, then ask questions. I'm assuming you are new.. great welcome! The search function is not great, but try it. You can find a lot by using Google and YouTube. Once you have gathered as much as you can, we are more than happy to offer advise. We have all been there. :-)
