transmission problem
1992 legacy fwd automatic. I put a trans in it over the weekend and it worked fine. I parked it yesterday and this morning. it started whining and now the car will move for a few seconds then lose all gears. full of fluid and no burnt smell. unplugged the dropping resistor and started it and the whining was worse. any ideas?
Edited by mr_strick
did you make sure to fully and properly seat the torque converter?
My guess is no, and that the drive tube snout is tearing up the pump drive.
Just throwing this out there but I have a low mileage FWD 4EAt saved from a 94 in case you may need another.
yes I made sure the torque converter was seated. the trans worked flawless till I parked it yesterday.
Edited by mr_strick
just in case how much?
1. check fluid level
2. make sure the flexplate is still spinning?
3. Early legacy's had a recall that I think involved too much debris clogging up the lines. Subaru offered an inline filter kit I think was their solution to that issue. I would make sure you're getting adequate fluid flow through those ATF lines.
You're in solid hands if you end up needing that trans, John is the man. You could even partly blame him for me knowing how to do anything more than change my oil since I met him like 20 years ago. I'm daily driving one of his previous vehicles as of last fall ironically!
Edited by idosubaru
fluid level is fine. the trans will hold gear while it is whining but once the whining stops the trans lets go. btw northern or southern ky?
Edited by mr_strick
Southern. About 50 miles due north of Nashville.
I,m in northeast Ms. So yea, got to get the money for it. No along drive
I live in Elkton, KY, not Elkton, TN. Let me know when you expect to be here.
John
does it still have the oil lines and stub shafts? will be a couple of weeks before I can get up there.
LInkage correct? I notice Subie linkage cables get very stiff.
