nicksubaru Posted September 18, 2017 Share Posted September 18, 2017 The carb is the weber 32/36 dgav 33b1, im not the one who did the weber swap. In the front of the carb there is something missing, after some searching i think its the primary idle jet and holder for it. I was able to plug it with a small alin bolt with the same thread. Now it will idle but what will happen if i dont replace the jet that's supposed to be in there? Is there a shop that i can go to in person that carries parts for this? (in California) The local o'reilly's does not have anything for it. I tried to order a new jet and holder online but its not right... Link to comment Share on other sites More sharing options...
naru Posted September 19, 2017 Share Posted September 19, 2017 (edited) IIRC,the jets? and holders come in 2 sizes for the DGV series carbs. Order the other one(s). http://www.dellortoshop.com/contents/en-us/p880_Idle_Jet_Holder_for_Weber_DGV_DGAV_and_DGEV.html Edited September 19, 2017 by naru Link to comment Share on other sites More sharing options...
nicksubaru Posted September 19, 2017 Author Share Posted September 19, 2017 IIRC??? I don't know what that means. So just the holders are 2 different versions ? They use the same jet? Or is there two different versions of the jets as well? I think i ordered the Smaller one so i need the bigger ones Link to comment Share on other sites More sharing options...
naru Posted September 19, 2017 Share Posted September 19, 2017 IIRC = if I recall correctly Website above shows 2 different sizes for both idle jets and idle jetholders. Link to comment Share on other sites More sharing options...
Nickoli Posted September 20, 2017 Share Posted September 20, 2017 If it's one of two openings on the front (facing the bumper of the car) they are both vacuum ports. I forget exactly, but the left one is connected and the right one can be plugged. try looking through loyale 2.7's weber swap guide and i bet it's there somewhere. the primary idle jet is on the driver's side of the carb, if i remember correctly. i can also check tomorrow. can you take a picture of what's missing? Link to comment Share on other sites More sharing options...
nicksubaru Posted September 20, 2017 Author Share Posted September 20, 2017 If i need a better pic of it let me know Link to comment Share on other sites More sharing options...
