Cracked inner axle
Anyone ever have the inner metal
Cylinder on their axle crack?
Edited by JWD06OBXT
Buy a used OEM axle and reboot it.
Www.car-part.com
Lifted off-road rigs break stub shafts and axles. Are you off-roading or clutch dumping a Crawford tuned special?
Aftermarket axles have any and every issue known to man.
Front or rear?
What do you mean by cylinder - the shaft, something inside the joint or the stub shaft?
I think he means the cup or the cage. Either way, some clarification or pics would help. You're right as usual though, AM axles just tend to suck.
  • 2 weeks later...
Www.car-part.com
Front or rear?
 Yup inner cage cracked in three spots. Pretty sure its cause the axle was toast cause when I took it off the car the joint actually locked up and had to force it back into the cup. Got a new to me OEM axle from the the Junk yard and it fit like a glove. Now just waiting for new tie rod ends.
