95 impreza air bag light
I pulled the dash to do a heater core t his weekend, and now I have an air bag light on. I only know of 3 air bag connections, 1 at the center console to the unity and then 1 to each side of the dash. All plugged in. Am i missing something else or is it possible when lowering the steering wheel, the clock spring somehow got messed up.
It's probably the clockspring. That's the most common to get messed up when pulling
a dash.
Does the horn work?
Read the codes (I'm not sure how on a 95)
Check all the connectors that they're good.
Edited by golucky66
Read the airbag codes.  There is a diagnostic connector under the dash behind the steering wheel with pins you can put in to read the codes.  It blinks the airbag light for long and short flashes to spell out the code.
Is it a yellow plug, and where does it plug in to
