April 16, 20187 yr Have 07 Impreza with two copper washers and a u shaped copper washer that hold the power steering pump hose on top of power steering pump with a bolt. Do the two washers go on the inside or the outside of the u shaped washer? Whatever I'm doing is incorrect because the power steering fluid is leaking from the connection between hose and pump. Edited April 16, 20187 yr by steve56
April 16, 20187 yr this is exactly where I had a problem, and wasn't sure if I put it back on correctly... Maybe just need to tighten the bolt more. What is the torque spec?
