Martin Posted June 30, 2004 Share Posted June 30, 2004 What is a good way to mod up the air intake for a ea82 carb'd motor? I have read lots on modding up the spfi's... can the spfi air intake be fitted to the carb engine, or is there just easier or better ways? Thanks. Quote Link to comment Share on other sites More sharing options...
PeterD Posted June 30, 2004 Share Posted June 30, 2004 i might be wrong buti don't think there is alot you can do. i have seen some mods but due to the ecessive amount of vacume lines and crap you can do a whole lot. Quote Link to comment Share on other sites More sharing options...
The Scooby Posted June 30, 2004 Share Posted June 30, 2004 i had a ghetto rigged system on my EA82 when i had the stock carb on it. it was a stock carb stud lengthened int he middle with another bolt, then get a SPFI intake, drill a whole in the top for the stuf, then use your stock wing nut to hold that on tightly, then put a cone filter where the spare tire is soposted to go and there you are, seemed a little better at higher RPM. Later, Shean Quote Link to comment Share on other sites More sharing options...
