August 29, 20196 yr hello, Just got a 1999 imprezza outback..nice rig but..... When you first start it up the idle bounces up to 2,000? and down ..Only for a few seconds? any ideas,thanks <todd oh ..its a 2.2 automatic Edited August 29, 20196 yr by old sub freak
September 2, 20196 yr Could be couple of things to start with: Coolant temperature sensor incorrect Manifold pressure sensor incorrect Throttle position sensor incorrect Vacuum leak (this would also result in normal rough idle) Those sensors can be tested on resistance, vacuum leak can be checked by closing the air-inlet before the filter with a or something that can close of the inlet. The engine will starve of air and stop. But if there is a leak it will make a hissing sound.
