1999 Legacy L Wagon Postal Transmission?
Hello all, I'm a new to owning my already beloved Legacy postal wagon. I picked it up on the cheap because it needs a new transmission but I've been having some trouble finding one.  I'm looking at a site called reman-transmission dot com and the only thing they have for the 1999 models is for a forester with a 2.5.  My legacy has a 2.2.  From what I've been lead to believe this forester transmission should work in my legacy but I'm hoping one of you gentleman can help me with this conundrum.  Thank you in advance to any of you that can assist me.
Thanks, that will be a great help.  Would you suggest I just purchase a used one?  I like all these meticulously remanufactured ones but is that just a scam?
they are pretty good transmissions.  I would buy a used one with a 90 day warranty.
The following is from a previous post. Being all wheel drive the gear ratio must match what you take out.
I also use this web site  https://www.hollanderparts.com/  to find parts.
Look up your vehicle then enter your zip code to sort closest to you.
transmission - transaxle.
Get the number on the sticker located on the bell housing above the starter or from the plate on the strut tower and using the chart in the attachment you can identify your transmission and a replacement.
The first 7 digits are the important ones. I found this chart somewhere when I needed a tranny for our 95 Legacy. TZ102ZA----
