Ej25 hla heads with ej251 block
Hi, every body I just had a question for you. I have a 96 ej25d with hla heads. It has rod knock so was wondering what headgasket i could use if i used an ej251 or ej253 shortblock. I know there are other posg similar to this but i could not find a definitive answer for the hla heads since the heads have a slighlty higher cc than the 97-99 heads. Thanks in advance.
Sorry im not to familiar to much with subarus is that the last numbers for the part number. Thank you
