July 6, 200421 yr Hi guys. Just want to know if there is something I can do get a better acceleration out of my '91 Legacy AT AWD non-Turbo. It doesn't have the pulling power it once had. Is it the AT, dirty injectors, engine clogged or something else? Or all? I changed the fuel filter back in 7/01, so it's probably not it. I used fuel injectors cleaner regularly in my gas, does that helps? As always, thanks in advance! JC
July 6, 200421 yr how many miles on it? last time you did plugs? wires? air filter? and yes... that fuel filter probably needs swapping Jamie
July 7, 200421 yr Author Thanks for the replies. I have never done a full tune-up on the car since I got it. It has like 180K miles on it now. I remember I bought and replace the plugs, air filter and fuel filter back in 7/01. Not much else since. The wires were never replaced, if I remember it correctly. I think I looked at them, determining that they looked good, no cracks no sign of any wear and tear so I thought they were still good. The Oxygen sensor also has never been replaced all these years. Perhaps it's time for a complete tune-up.
