2012 Impreza - Blinkers/Hazards not working, relay is good, A/T Trans light turns on and refuses to shift
Hi all, I'm hoping I can get some help on this problem that's got me completely stumped. So a breakdown of my problem:
- Blinkers won't turn on in the dash or the bulbs and when I try to turn them on, there is a fast electrical sounding clicking somewhere in the dash or underneath it
- After a few minutes of the car being on, the A/T light will start flashing and the car will refuse to shift into or out of park/reverse
- I changed the relay and it didn't do anything so I left it unplugged and it will immediately not shift after turning on
- I gave power directly to the wiring through the bulb and the front and back flashers turned on perfectly
If anyone has heard of any fixes for this or has had a similar problem I would really appreciate any info!
It sounds like you may have a bad connection to power on the supply line to the flasher line. I assume the sound you are hearing is the flasher unit. Does one side of the blinkers work?
