February 26, 20206 yr is it possible to disconnect the power locks from the keyless and have them still work? ive been trying to bypass the power locks so the keyless unit wont see them operating. when i unplug the keyless unit the power locks stop working all together. ive looked at the fsm and tried to unsolder the pins from the keyless for the locking system and bypass them by jumping the inputs to the outputs and still do not get power locks. the power locks do work if i have my un modified keyless unit installed. the reasoning for this madness is i want to make the factory security work with a remote starter but from what ive gathered it only arms and disarms from the factory fob. so far ive modded my factory fob so i can activate the lock and unlock buttons on it by 12v from relays. if i wire the factory fob into the remote starts lock commands it will run the factory fobs cycle and arm/disarm the securty as well as lock and unlock the doors but theres an issue running it that way. the factory fob wont unlock the doors if ive remote started the car. round 2 i tried hooking the remote start to control the locks and to activate the factory keyfob at the same time. in this configuration it runs the door locks and the fob at the same time but even though the fob lights up like ti sent the command it will not arm/disarm the security while the door locks are being activated. so this is where i am now i thoght i could make the keyless module just simply not see the lock system by jumping around the keyless but that dident work when i tried to plug the module back in the power locks did not work. i do have 3 keyless modules so this mod was done on one of the spares. so my question is what do i have to do to make the power locks function without the keyless module in the mix Edited February 26, 20206 yr by sirtokesalot
February 27, 20206 yr Author well i figured out a way to make it happen. i used 2 keyless modules. one keyless module is allowed to see the locking system but not allowed to talk tot he security module the other keyless module is allowed to talk to the security but not the locks. power locks now work and i can arm/disarm the factory alarm using my remote starter fob.
February 27, 20206 yr Author 3 hours ago, Rampage said: If only you could program those modules to work the way you want them to. that woulda been nice. the big issue i had was making the locks work and security arm at the same time. for some reason the cars keyless module wont arm/disarm the security if the locks are being operated at the same time a second issue i had was that remote starting would make the alarm go off but that was easy to remedy compared to the lock thing. i had to make the security think the locks were not being operated for it to arm/disarm while the remote starter did the actual lock controls. in order for this to work thogh required having a keyless module installed due to power locks not working at all unless it was there. thuse 2 keyless modules one being able to see locks but not security and one being able to see security but not locks.
