March 6, 20206 yr My 1980 Brat ea71 is having an ignition issue. There is a box located right next to the coil that says "transistor IGM." It malfunctions whenever I hit a bump and the car studders and I lose tachometer function for a split second. It stopped working completely once. I got out and traced the wires from the disty back to this box. I banged on it and it started working. I punched in the numbers that were on it and nothing even came up. What is it and where can I get a new one? Thanks!!! Edited March 6, 20206 yr by Marks02
March 7, 20206 yr That is your ignition module.Subaru also calls it a control unit. Wreckers are the only source I know. 80 Brats and all 79 4wds have this part. Might be worth opening it up and resoldering. Pretty sure you could use a later style disty w/an internal module if you are unable to locate this part.
March 7, 20206 yr Try this site. I used zip code 86402 and two listings showed up. One in Ontario and one in Virginia. They list it as Ignitor/Coil. You would have to call the yards to see if the Ignitor is still on the coil bracket and if they still have it. Some of them take a long time to remove their listings. http://www.car-part.com/index.htm Have a look at this post. It is two pages long. See if your part looks the same. https://www.ultimatesubaru.org/forum/topic/170502-can-someone-tell-me-where-i-can-get-a-ignition-transistor-or-is-it-possible-to-bye-pass-it-on-a-90-loyale/ If I had more info on the part I think I could make one.
March 7, 20206 yr Author Thank you both for the help. I think I'm gonna go with a newer disty. I've tried to find one before and came up with nothing. I know that it needs to be from an '83 or newer N/A EA81.
March 8, 20206 yr Author So I've found 2 different distributors on rock auto. I know that they are odd brands, but I need one. Which one of them should I get? And will one of these solve the issue? Here's the link. https://www.rockauto.com/en/catalog/subaru,1983,brat,1.8l+h4,1267691,ignition,distributor,7108
March 8, 20206 yr Either should work as they both have self contained ignition modules,but,the Hitachi is slightly more robust.
