910GL Posted May 18, 2020 Share Posted May 18, 2020 Doing an EJ swap and also adding power steering (my GL has manual steering). On this rebuilt EA P/S rack, which is the pressure and which is the return (red plug vs black)? Thanks guys Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 18, 2020 Share Posted May 18, 2020 EA82 or EA81? I don’t know which way the hoses go, in Oz, being RHD, the lines from the pump just “line up” with the rack on the EA82. On the EA81 the end of the EJ hoses needs to be flared. I think (but could be wrong because I’ve only seen on here and not in the flesh) that you also need the hose hard lines that run across to the RHS to meet up with the pump lines. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
910GL Posted May 18, 2020 Author Share Posted May 18, 2020 It's EA82. I have the hard lines that run across the subframe as well as the hoses that connect from there up into the p/s pump, all from the EJ. I'm sure I'll have to tweak them a tad to line up, just unsure which is pressure/return on this EA82 rack. Thanks Quote Link to comment Share on other sites More sharing options...
910GL Posted May 23, 2020 Author Share Posted May 23, 2020 Bump Quote Link to comment Share on other sites More sharing options...
