May 24, 20205 yr Swapping from carb'd EA82 to EJ. I've read that I need to upgrade the fuel lines in the process. Do I need to replace ALL of the fuel lines on the car or just the supply lines? (Are the return/evap lines ok to leave?) Thanks Brett
May 24, 20205 yr All high pressure lines need to be replaced with EFI grade fuel line. If you don’t do this, you’ll burst a fuel line and have all sorts of issues that could include a fiery end. Cheers Bennie
May 25, 20205 yr Author Bennie, Thanks for the reply. I replaced every section of supply line with EFI grade: all the way from the tank to the intake manifold (think it was like 5 or 6 different sections). I was back there anyway swapping the fuel pump. I also replaced the return line and evap lines in the engine bay with EFI grade (just the sections from intake to firewall). There are several sections of return and evap lines back at the rear of the car that I haven't swapped. Think these are good? They shouldn't be under pressure right? My thought is to leave 'em. Thanks: Brett Edited May 25, 20205 yr by 910GL
May 25, 20205 yr The rear return line low pressure hoses *should* be ok. Good time to swap them anyway if they’re factory units (most likely are). Cheers Bennie
