Carb to MPFI Fuel Lines
Swapping from carb'd EA82 to EJ. I've read that I need to upgrade the fuel lines in the process. Do I need to replace ALL of the fuel lines on the car or just the supply lines? (Are the return/evap lines ok to leave?)
Thanks
Brett
Bennie,
Thanks for the reply. I replaced every section of supply line with EFI grade: all the way from the tank to the intake manifold (think it was like 5 or 6 different sections). I was back there anyway swapping the fuel pump.
I also replaced the return line and evap lines in the engine bay with EFI grade (just the sections from intake to firewall). There are several sections of return and evap lines back at the rear of the car that I haven't swapped. Think these are good? They shouldn't be under pressure right? My thought is to leave 'em.
Thanks: Brett
Edited by 910GL
