August 3, 20205 yr Got a 95 ,2.2 LTR. outback. When approaching to a stop or at an idle, the engine cuts out. But it will start right back up. When driving at normal speeds on the road, it runs fine. any suggestions what the problem is ?? Thanks-- bill
August 3, 20205 yr idle air controller/valve. clean or on these models it usually needs replaced. they fail rarely enough that a used one is a reasonable option. but that's only a guess, which isn't ideal - answer lmdew's questions above
August 3, 20205 yr Author thanks for the comeback. This 95 subaru has the automatic trans in it. the last time I worked on this car, the engine light was off. the lady who owns this car told me that is on now. I still need to get down to test for the problem with the engine light.
